Timing belt replacement
Old 07-21-2010, 11:34 AM
RICK167448's Avatar
Smile Timing belt replacement
Hi! I have a 2007 chevrolet hhr ls, 2.2 liter engine, with 25,000 miles on it. I would like to know if and when i should have the timing belt replaced. Does anyone know? The owner's manual makes no mention of it. Thank you
RICK167448 is offline
Old 07-21-2010, 11:48 AM
These engines have a timing chain...... shouldn't need service for a long, long time.
Greybeard999 is offline
Old 07-21-2010, 03:00 PM
Laco's Avatar
In theory, that timing chain should last the life of the engine.
Laco is offline
Old 07-21-2010, 07:12 PM
mikey12561's Avatar
I wonder if he was referring to the serpintine belt?
mikey12561 is offline
Old 07-21-2010, 07:22 PM
He was.... in his other thread..... https://www.chevyhhr.net/forums/general-hhr-4/serpentine-belt-replacement-30818/
Old 03-25-2011, 01:54 AM
1Panel2NV's Avatar
Originally Posted by mike6187
I just got my old Bando timing belt replaced, it was on its 69000 miles. And based on my research, timing belt should be replaced every 50,000-70,000 miles. Car makers already specified the replacement intervals for timing belts.
See timing belt information about your car here:
http://autorepair.about.com/od/gloss...-belt-info.htm
I hear the intake manifold gasket can start leaking coolant around 75,000 on these cars. You might want to look into that too.
1Panel2NV is offline
Old 03-25-2011, 03:30 AM
And the muffler bearings should be repacked every 50,000 miles, or once every 3 years, whichever comes first.
whopper is offline
Old 03-25-2011, 03:45 AM
IgottaWoody's Avatar
Remember back when a timing chain actually could jump time? And fan belts actually turned the fan?
IgottaWoody is offline
Old 03-25-2011, 09:11 AM
I have three where the fan belt is still a fan belt ('67,'61'and '37), and aren't the muffler bearings on the HHR's sealed?
843de is offline
Old 03-25-2011, 09:18 AM
solman98's Avatar
Not needed if your running one of these.
solman98 is offline
Quick Reply: Timing belt replacement
