Timing belt replacement
Kuhneutson Valve(AKA "Kneutson, Kanutson") Our superior Kuneutson valves are superior to the inferior kuhneutson valves! For use especially on engines with camshafts. The number one sign of Kuhneutson failure is reduced bore on your engine block! Easily remedy this with a Kuneutson Valve from KaleCoAuto! Now compatible with modern computer controlled cars. Coming soon...The Stage 1 package upgrade.
I bought the muffler bearing... guess the ones on the HHR are a small size.
Crap. Off to UPS for a return I go.
And that blinker fluid really does the trick. It was tough to find the reservoir but I found it. I was skeptical at first TBH. I thought it was all just a load of crock. The only thing I've noticed since adding the blinker fluid is that my car seems to hang between shifts. At least they're smoother now.
#28
#30
I just bought wheelie bars! They come with a lifetime waranty, ga-run-teed to be completely useless for the entire life of your FWD car.
Oh and the Tank Kit, I almost wish was real(for that morning commute)
BTW, Love this thread, suprised it hasn't been moved.
