Timing Chain Guide Bolt
From what I've read here, it seems it's possible to replace the timing chain guide bolt with the improved version by simple removing it and cranking in the new one. (I have a Dorman here.)
I'm paranoid that things won't line up and I won't be able to get the new one installed, not to mention worried about dropping or breaking the old bolt.
BTW I have the valve cover off and timing chain is tight so for a number of reasons I'm putting off changing the chains for now.
2010 SS 5-sp 110K miles.
Use a magnet to remove the old upper guide bolt, and install the new replacement bolt. I’d still change the chain set . Have a look at the front guide they tend to break around 100 to 125,000 miles.
OK. The chains will be done soon, but I‘m thinking about other work too and it may make sense to just drop the engine cradle and do everything at once. We’ll see. Wish someone made better plastic chain guides that won’t break.
Very helpful to understand. I’m taking your prior comments as assurance that if I remove the top bolt, the guide should stay in place and it should be possible to properly insert the new improved bolt. Will be doing that today. And another HHR with just 70K miles or so soon. -signed, Worry Wart.
I've done a few of these, but always with no tension on the chain.
I would be afraid the guide would move sideways from the chain tension and you wouldn't have any way to align it.
It might be better to remove the tensioner and then replace the bolt.
Steve
Steve
