Tire Pressure
Old 10-15-2009, 06:09 PM
09 HHR's Avatar
Tire Pressure
I have a 2009 LT 2.2 with 16 inch wheels. What should I be running the tire pressure at.
09 HHR is offline
Old 10-15-2009, 06:33 PM
photojoed80's Avatar
Stick with what the tag says inside the driver door. Ususally 32-35 lbs.
photojoed80 is offline
Old 10-15-2009, 07:24 PM
txbass06's Avatar
I was running 34 psi in mine
txbass06 is offline
Old 10-15-2009, 07:55 PM
hyperv6's Avatar
Read your wear if the center is more worn let some out if the edges are wearing add a few pounds.
Also you may need to run less in the back since it has less weight.
Start at 32 and adjust from there.
hyperv6 is offline
Old 10-15-2009, 07:58 PM
09 HHR's Avatar
I just got the HHR and it has 4300 miles on it ans according to the moniter all the tires are reading different. So I am looking for a comfortable starting point.
09 HHR is offline
Old 10-15-2009, 09:16 PM
txbass06's Avatar
I wouldn't rely solely on the TPMS system. I've got a good pressure guage that I use when I check the psi in my tires and only use the TPMS to keep an eye on things.
txbass06 is offline
Old 10-15-2009, 09:50 PM
hyperv6's Avatar
Like I said 32 PSI is a start and then read the tires from there. You could even go 30 in the rear if you like. I would just not go less than 30 to start with.
Keep in mind higher pressures will give a slight increase in MPG but can wear the centers of the tires sooner. Less will generate heat in the tires and wear the outer edges.
30-32 will not hurt anything and give youy a place to start.
hyperv6 is offline
Old 10-16-2009, 01:39 PM
09 HHR's Avatar
Thanks for the info guys
09 HHR is offline
Old 10-16-2009, 02:17 PM
Comfortably Numb's Avatar
First you should open the drivers door and look at the label that is there in all cars made in the last 30 years or more. Then you should use a tire gauge to check each one individually and adjust accordingly. The TPMS is an incredibly poor thing to use for accuracy, it is an emergency use only item that is designed to get your attention when a tire is losing pressure. It has gotten to where people are relying solely on it and dieing because of it.
Comfortably Numb is offline
Old 10-16-2009, 02:36 PM
Jim's 2009's Avatar
I run 40psi in mine and at 21000 miles tires are wearing perfect. I do it for mpg and it's not hurting the tires at all. And I average 34-37 mpg on a 2.2.
Jim's 2009 is offline
Quick Reply: Tire Pressure
