Tire pressure, DIY oil change questions
Tires need the correct amount of air pressure to operate
effectively.
Notice: Do not let anyone tell you that
under-inflation or over-inflation is all right. It is not.
If your tires do not have enough air (under-inflation),
you can get the following:
• Too much flexing
• Too much heat
• Tire overloading
• Premature or irregular wear
• Poor handling
• Reduced fuel economy
If your tires have too much air (over-inflation),
• Unusual wear
• Poor handling
• Rough ride
• Needless damage from road hazards
I change my oil but probably don't have all the receipts...I don't expect the engine to fry in this car due to a lube problem...I keep an Excel Spreadsheet of my changes and I hoard oil so the dates of my changes and oil purchases could be a year apart.
Change your own oil...there is no easier engine in the world to change your own oil than on the Ecotec
Goose
Goose
TEKNOnaut
Tires & Wheels
7
09-18-2012 07:43 AM
