Towing A Five Speed Manual Front Wheel Drive Hhr
Old 04-11-2007 | 06:12 PM
baldeagle31840's Avatar
Can A Hhr With The Five Speed Manual Be Towed Behind A Rv With Out Any Modifications. I Know On A Rear Wheed Drive Just Put It In Nutral And Tow. But I Do Not Know If The Same Is True For A Front Wheel Drive Such As The Hhr. The Dealer Service Dept Did Not Know For Sure, Where Can I Get This Information.
Thanks
Old 04-11-2007 | 06:15 PM
Size:  5.6 KB to the site!!! Owner manual states that it can be Dinghy towed (all 4 wheels on the ground)!
1. Set the parking brake
2. Turn the ignition key to ACC to unlock the steering wheel
3. Shift your transaxle to Neutral
4. Release the parking brake
Old 04-11-2007 | 06:33 PM
Forgot this part
Important note: To prevent battery from draining while the vehicle is being towed, remove the following fuse from the floor console fuse block: 8 (Ignition Switch, Pass Key III) Remember to reinstall the fuse once you have reached your destination.
Never exceed 65mph while towing your vehicle.
DaytonaBlueMetallic
08-15-2015 07:35 AM
kewatin
Maintenance and Upkeep
11
12-16-2014 01:33 PM
Doctuh
03-23-2014 06:41 PM
Bosshound
08-14-2008 10:22 AM
gksmith6
2.4L Performance Tech
03-02-2008 08:32 PM
