Towing the HHR
Mine happens to be a five speed, though GM says towing the automatic is not a problem either. Flat towing either the five speed or the automatic does not affect the warrantee, nor does the odometer register towed miles.
Go to www.rv.net
Specifically check Dinghy Towing : http://www.rv.net/forum/index.cfm/fu...s/forum/31.cfm
There are a bazillion threads about "toads" and specifically the HHR. I know there is some issue with the SS (requires different plates for the bar).
But if you can't find what you want there, it doesn't exist.
Terry
Terry
If you have an SS, you have to source your baseplates from Demco. Roadmaster and Blue Ox don't make them for the SS.
You also have to remove fuse #8 while towing for all HHR models. Some fabricate a switch or buy a kit for this purpose.
Links for both are below:
Demco Base Plates
http://www.demco-products.com/baseplates/fitlist.html
Fuse Switch
http://www.rv-partsplus.com/home/accessories/
Demco Base Plates
Fuse Switch
