Towing the HHR
Old 02-11-2010, 01:06 AM
lenv's Avatar
Towing the HHR
Is there anyone here who has or is towing their HHR behind a motorhome? If so what has been your experience?
lenv is offline
Old 02-11-2010, 01:32 AM
lenv-
WELCOME, I read about someone here tows theirs.. Just can't remember who ?
Hopefully they will chime in here..
sleeper is offline
Old 02-11-2010, 06:44 AM
masterchief1112's Avatar
use the search function and you will find plenty of threads about this, i think there is a fuse you want to take out so that the battery does not get drained.
masterchief1112 is offline
Old 02-11-2010, 04:52 PM
Laco's Avatar
I tow mine and have been for almost three years.. What kind of info are you looking for?
Laco is offline
Old 02-11-2010, 05:38 PM
ChevyM84's Avatar
i wouldnt think it would be a good thing unless gm has designed the trans different. i would think the trans would be moving even in neutral with no oil pressure?????
ChevyM84 is offline
Old 02-11-2010, 06:11 PM
Laco's Avatar
Mine happens to be a five speed, though GM says towing the automatic is not a problem either. Flat towing either the five speed or the automatic does not affect the warrantee, nor does the odometer register towed miles.
Laco is offline
Old 02-11-2010, 08:02 PM
esmarkey's Avatar
The HHR WAS designed for flat (dinghy) towing.
esmarkey is offline
Old 02-12-2010, 03:23 PM
terryk's Avatar
Go to www.rv.net
Specifically check Dinghy Towing : http://www.rv.net/forum/index.cfm/fu...s/forum/31.cfm
There are a bazillion threads about "toads" and specifically the HHR. I know there is some issue with the SS (requires different plates for the bar).
But if you can't find what you want there, it doesn't exist.
Terry
terryk is offline
Old 02-13-2010, 09:20 PM
87silver's Avatar
If you have an SS, you have to source your baseplates from Demco. Roadmaster and Blue Ox don't make them for the SS.
You also have to remove fuse #8 while towing for all HHR models. Some fabricate a switch or buy a kit for this purpose.
Links for both are below:
Demco Base Plates
http://www.demco-products.com/baseplates/fitlist.html
Fuse Switch
http://www.rv-partsplus.com/home/accessories/
87silver is offline
Old 02-15-2010, 03:10 AM
Brucet's Avatar
Have been towig our 2007 LT auto now for 2 years. No problems. The one down side though is that the front of the HHR is so low that the tow gear will have to be lifted to keep things level.
Brucet is offline
Quick Reply: Towing the HHR
