Transmission add-on
Transmission add-on
I was thinking - it would be kinda neat to have indicator lights displaying gears on/off (1,2,3 & 4). Maybe mounted on the column or on the fall just below the hazard button. Anyone know if this or something similar has been done?
CAN it be done? What do you think?
Thanks for your knowledge/thoughts/ideas.
It could be done but would be a lot of work. Wiring, sensor, gauge. Plus, exactly what kind of parts would you need?
Funny thing though is my SS with the 5 speed already has a gear shift indicator in the RPD. Must have some kind of gear sensors in the transmission, or maybe on the shifter itself. Not sure what the SS with the auto trans. shows on the RPD.
Attachment 16252
Attachment 16252
George, heres what I'm thinking: I'm guessing there are wires (or a wire) coming off the TCM that switch the solenoids inside the trani. If I'm right and I can isolate which wire(s) controls which gear then I can tap off those to individual LED's. What do you think?
