Transmission add-on
Old 05-22-2014, 12:24 AM
11hhrlt's Avatar
Transmission add-on
I was thinking - it would be kinda neat to have indicator lights displaying gears on/off (1,2,3 & 4). Maybe mounted on the column or on the fall just below the hazard button. Anyone know if this or something similar has been done?
CAN it be done? What do you think?
Thanks for your knowledge/thoughts/ideas.
11hhrlt is offline
Old 05-22-2014, 09:09 AM
It could be done but would be a lot of work. Wiring, sensor, gauge. Plus, exactly what kind of parts would you need?
Funny thing though is my SS with the 5 speed already has a gear shift indicator in the RPD. Must have some kind of gear sensors in the transmission, or maybe on the shifter itself. Not sure what the SS with the auto trans. shows on the RPD.
Attachment 16252
firemangeorge is offline
Old 05-22-2014, 10:59 AM
celblazer's Avatar
The SS Auto shows the same display minus the stick indicator at the bottom.
celblazer is offline
Old 05-22-2014, 12:25 PM
OBDII reports gear.
donbrew is offline
Old 05-22-2014, 10:44 PM
LVJJJ's Avatar
This is blasphemy, so cover your eyes. Once had a 1990 Mitsubishi Mirage that had trans gear indicator lights in the instrument cluster, was a nice feature.
LVJJJ is offline
Old 05-23-2014, 12:35 AM
11hhrlt's Avatar
George, heres what I'm thinking: I'm guessing there are wires (or a wire) coming off the TCM that switch the solenoids inside the trani. If I'm right and I can isolate which wire(s) controls which gear then I can tap off those to individual LED's. What do you think?
11hhrlt is offline
Old 05-23-2014, 12:42 AM
11hhrlt's Avatar
Originally Posted by donbrew
OBDII reports gear.
Great. So it looks like this could be done but which wires? A schematic would be a big help. The Chilton manual doesn't show anything for the trani.
11hhrlt is offline
Old 05-23-2014, 01:42 PM
It's digital, you would need a decoder.
donbrew is offline
Old 05-23-2014, 02:29 PM
Like my classic Buck Rogers secret decoder ring??
Oldblue is offline
Old 05-23-2014, 05:45 PM
Shirley Temple decoder ring works best.
donbrew is offline
Quick Reply: Transmission add-on
