Transmission Cooler Install...Anyone Do?
I have a 2LT with Auto, 2.4L that I am trying to install a Hayden brand transmission cooler. My problem is I can't find the proper adapters that will fit onto the existing lines that run into the radiator. Has anyone installed a cooler and where did you find the right adaptors? Thanks.
Go to a shop
My thoughts also. If something can be done, there is always someone who will somehow get er done
Just be careful not to cool to well. unless you tow a lot with your HHR, [Tow with a HHR????] a trans temp gage would be better.
trans fluid like eng. oil has a operating temp that it should run at and the cold can be as bad as over heat IMO: my 2cents:
I just saw a B&M cooler that claims to automatically bypass the cooling element when the fluid is cold. Must be something to what you are saying. The transmission is not actually sealed. It has a plug for changing the fluid but no dipstick. I do wonder how you would get the level right because your capacity would have to go up with the additional tubing. I think as soon as my warranty is up I'll just install the B&M. It requires cutting the hose (universal kit). I tow a small utility trailer occasionally and even though it is not overloaded I still like a cool tranny.
I just had a Continental Transmission shop put one on Stitch II. Thus far, doesn't seem to be having any issues in regards to either leaking fluids or tranny getting too cool. (Plus, it didn't cost too much, a little over $200 for parts and labor because it was easier than they thought it would be.)
