Transmission fluid
I’ve used Mobile in my 2007, and I put Castrol synthetic in my 2011, both times I installed an AC Delco filter, wiped off and cleaned the OEM gasket, (Dawn and water) and retorqued the bolts to the specifications of 106 inch pounds . It’s an 8 mm socket for the bolts. Be careful not to over tighten them !
a_bartle
Maintenance and Upkeep
07-20-2017 02:21 PM
