Turn signals
From the BCM which also does the flashing and brakes. That's right; no flasher module and the brake pedal switch is really a sensor. No dedicated fuse, one of the BCM fuses in the underhood box supplies power to the BCM to use. The BCM itself is powered from the big fuse near the battery.
Farmers Daughter
03-31-2014 06:09 PM
