Tweet tweet goes my HHR
Nice weather today a little breezy but still rode with all the windows down traveling about 40 MPH I started hearing an intermitant whistle sound then steady. Thought it might be the radio station so I changed it, still there next I put up the windows and it stopped. I then put them back down and it came back. I happened to open my dash vents which were closed and the noise stopped. The fan was not on and output was set to upper vents only. I also noticed quite a bit of air comming out even with the fan off. Has anyone had this happen to them? Why is there that much air coming out with the fan off?
I bet your AC was set to "fresh air". It would be the "wind rush" coming in through the vents. Shouldn't happen if it were set to "recycle".
I wonder if anything can be done to eliminate this noise...I think mine is coming from the mirrors but not positive....if I put my windows up I can still here it sometimes
Not all HHRs do this though as the other 3 I have driven as rentals did not do this...I will try the recirc thingy
Sort of sucks
Goose
Sort of sucks
Goose
