Two questions
Old 08-09-2013, 12:47 PM
zabadubarbara's Avatar
Two questions
Since I'm trying to learn about cars, I'm trying to decode things. I need a little explanation.
I have a 2.2L L4 DOHC 16V FFV.
1. I think it means I have a 2.2 liter engine with an L4 suspension, and that it has 16 valves, but the rest means nothing to me. And having an L4 suspension and a 2.2 liter engine means what?
2. Also, I had no idea I had a power front seat lumbar control. Is it in front of or behind the seat forward/backward slide switch? On my dads old Monte Carlo, there was a button. I've never known mine had it, but it says it's standard.
zabadubarbara is offline
Old 08-09-2013, 01:02 PM
db/sb's Avatar
2.2L L4 DOHC 16V FFV means 2.2 liter displacement, L4 means it's an inline four cylinder engine, 16V is 16 valves (4 valves per cylinder) and FFV means Flex fuel vehicle which means it runs on an alternative fuel like ethanol or methanol as well as gasoline.
db/sb is offline
Old 08-09-2013, 01:30 PM
Thank you. Still don't understand what liter displacement is. I'll look it up.
Old 08-09-2013, 01:38 PM
db/sb's Avatar
Engine size. 2.2 liters is 2200 cc (cubic centimetres) or roughly 134 cubic inches. In the case of the Ecotec 2.2 it's actually 2198 cc.
db/sb is offline
Old 08-09-2013, 01:40 PM
It used to be cubic inches, now that the Canadians are getting ready to invade we arte using metric.
The lumbar support button is the rocker switch behind the adjuster button. You obviously need an Owner Manual, the dealer that sold you the car is responsible for supplying one to you either by reimbursement or an actual copy. One is also available here.
https://www.chevyhhr.net/forums/general-hhr-4/online-owners-manual-3074/
donbrew is offline
Old 08-09-2013, 01:48 PM
the_shmoo's Avatar
donbrew good one I like that. watch out
the_shmoo is offline
Old 08-09-2013, 02:38 PM
https://www.chevyhhr.net/forums/showthread.php?t=3074
I have one, I just haven't read it cover to cover. But thank you for the link and the info. I really am NOT the dumb blonde I appear to be....
Ah, size. Thank you!
Old 08-09-2013, 06:37 PM
jay loukakis's Avatar
Every car I have owned the first thing is buy the factory manual for the HHR 2 books like phone books 40 lbs. cost $182.00 and well worth it as it has all of the codes and more info than you will ever need, but no schematics just block diagrams.
jay loukakis is offline
Old 08-09-2013, 07:46 PM
Sno White's Avatar
Originally Posted by jay loukakis
... but no schematics just block diagrams.
My 2009 FSM from Helm has three volumes and lots of schematics; perhaps you didn't receive the complete set.
Sno White is offline
Quick Reply: Two questions
