V8 HHR Build
#812
I'm telling you, this build wouldn't happen without forums to answer questions. Thanks guys!
#813
With all your know how, I don't see why you couldn't use a bottle of MAP gas from Home Depot rigged to an igniter and a solenoid to heat the O2 sensor.
I mean the rest of your build is Hi Tech.
"Don't shoot me I'm only the piano player."
#816
That's because it's not really MAPP gas but a substitute. Contrary to the post above, MAPP gas isn't illegal; it's just that the only place that made it in the US stopped making it in 2008. The new stuff is essentially just LP gas.
#817
They have three wired heated O2 sensors, I had one in the headers in my old show truck
Installing a 3-wire Heated Oxygen Sensor --SETHIRDGEN.ORG--
#819
That's a very good question, This being a California car, it will never pass emissions completely. I am however trying to give the illusion of compliance. The rear O2 sensors are just one piece of the puzzle. Weather or not the sensors are used will be determined later. The rear sensor bungs may be capped off. Don't know at this point. But at least it is plumbed fo it.
#820
