Vin vs build tag
Old 08-10-2019 | 10:02 PM
Tokin's Avatar
Vin vs build tag
My vin says I have a 2.4 engine while my build tag in the glove box says 2.2. Which do I believe?
How can I tell the difference by looking?
Vin 3GNBABDB9AS59XXXX
Thanks!
Old 08-10-2019 | 10:06 PM
Do the vin numbers match , base of the windshield and that sticker?
Old 08-10-2019 | 10:08 PM
Tokin's Avatar
Yes they do
Old 08-10-2019 | 10:17 PM
Up on the top tool bar on the left side click TOOLS then click VIN decoder. One reason may be that different years had different engine codes.
Your VIN shows B in the eighth position for 2.2L/LE8 in your 2010 HHR.
__________________
Old 08-10-2019 | 10:52 PM
Tokin's Avatar
Hmmm, could be I read the vin wrong but I think maybe carfax had the wrong info. Should've came here first.
Old 08-10-2019 | 11:20 PM
See post #37 in this thread https://www.chevyhhr.net/forums/gene...r-12317/page4/
RPO LE8 is 2.2L
Old 08-10-2019 | 11:28 PM
Silverfox's Avatar
1LT could have either engine.
It would have 2.2L standard and The 2.4L would be an option.
Look carefully at the Exhaust pipe and see if it has a welded on Stainless tip with the opening cut at a slight angle.
If it has that tip then you have a 2.4L
Silverfox
Old 08-11-2019 | 04:27 AM
From the 2010 Owners Manual, page 6-126 :
2.0L L4......... Engine M
2.2L L4......... Engine B
2.4L L4......... Engine V
Old 08-11-2019 | 09:30 PM
Silverfox
Yes, 2.4 ONLY will have the 3-1/2" across exhaust tip.
Old 08-12-2019 | 08:41 AM
And above the 14B your sticker shows 1LT.
I believe you have a 1LT , LE8 confirmation with that B in the eighth digit in the VIN
Quick Reply: Vin vs build tag
