Want to remove a screwup
My 2009 HHR is 2 weeks old to me, and I added chrome door handle trim and I hate them. I think they look cheap and I want to know if I can remove them. I attached with 3M adhesive enhancer like I was instructed to and I did all four. I wanted to dress up the door interior, but after looking around I found a 57 Chevy script that I like a whole lot better, I guess I jumped to fast and did not put a lot of thought into it.
Please help,
ck1951
Not quite sure what you are asking - you did remove them? Is there residue left over? If so, go to a hardware store and buy goo-off. It will cut the residual glue and you'll be fine. You can also use lighter fluid carefully, followed by some wax. DO NOT use lacquer on it - you'll kill the paint.
I take it the OP is asking about the interior trim rings such as these.........
http://hhrboutique.com/items/hhr-int...301-detail.htm
Would have to agree w/ AJ, after prying the rings off, use goo-off or some other brand of adhesive remover. There should be no need to worry about the stuff hurting the plastic panel, just be careful prying off the rings.
