Wanting to find shocks for my 2007 HHR
2007 HHR LT
Mechanic said my shocks were shot and needed replacing.
Which of the following is the better choice.
I only drive in the city and do not drive fast or hard.
My sticker says FE1.
KYB 349043 Excel-G Gas Shock
ACDelco Professional 530-456 Premium Gas Charged
Both are $33 shipped and sold by Amazon.
thanks
thanks
FE1 - softest ride (LS), FE3 - a little stiffer (LT), FE5 - way stiffer (SS)
Have you looked into RockAuto.
They are a sponsor here AND we get a 5% discount.
You will also receive a cool magnet to start your collection.
Personally I installed KYB in the rear.
I also installed a TTR sway bar and Colbalt TC/SC springs.
Is the 5% discount given to HHR in addition to the readily available 5% discount coupon that can be found with Google?
I usually research the part# at Rockauto but prefer the easy Amazon return policy in case I screw up.
Glad to hear your vote for KYB! But I don't know what Colbalt TC/SC springs are.
I went with KYB Excel-G, Strut-Plus, the ones with the spring and mount included and pre-assembled, and KYB Excel-G shocks for the rear. I went with the strut/spring combination because you save time and grief by having the entire assembly even though the initial cost may be a bit higher. Your mechanic will love you for doing the combo and you should save at least a half hour or more in labor cost. If you're remotely able to do your own work on your car, the rear shocks are literally a half hour job with just two sockets and a breaker bar or ratchet wrench.
I just put a new sway bar and it is noticeable, but I think the struts/shocks made the biggest difference, but if you're having the shocks done, now would be the time to do the sway bar too for about $150.00.
I can only compare to the old worn ones and the KYB but I will say the car handles very well for what it is. Does it ride like an old Caddy, or corner like a Camaro, absolutely not, but it has a ride that seems to be the perfect compromise between handling and smoothness.
