water in passenger side
Driving home tonight with the ac running, as I made a sharp turn my wife said she heard water slosh onder the dash and dump on her shoes and the floor was soaked. I believe this is a clogged drain, where can I access this as I coundnt get to anything tonight and want to clear it tomorrow if thats the issue... it wasnt raining , just the ac running.
Thank you all again. I could see the spout from above the airbox and I have an extension for my blow gun that would reach the spout easily, I blew a soft puff and out poured the water, so I gave it a few more short bursts to break up anything and flush it out... It seemed like a gallon poured out as I waited for the water to stop gushing out. Then I got the shop vac and sucked the water out of the carpet, when I opened the shop vac there was almost a gallon of water in there as well, so apparently this has been going on for awhile and I just havent noticed it ( since Im usually the only one in the car most of the time. Since I was at it, I went ahead and vac'd all the floorboards . Shouldnt have any issues for awhile I assume, Ill pick up a can of cleaner/freshener to spray in there, although there are no smells now, and hopefully none later. The cabin filter is new ( but the old one was really dirty when I bought the car last year... so theres that chance.
