Weak Window Motors
It's not the temperature,it's the moisture in the air that freezes the crappy window seals to the glass.You might try running a credit card in the gap between the seal and the glass and see if that does anything to help.
What he ^ said, seal retains moisture and is actually freezing to the glass (happens on a number of vehicles). Motor is strong enough but amperage is monitored so it will not break frozen seal loose. When cleaning windows, gotta break seal away from glass (I do it by habit).
Thanks guys,I'll try that next time.I was wondering if the moisture was freezing on the seals but I figured the motor would have been strong enough to break it loose.Thanks for the info !!
