Weird Exhaust Sound
Weird Exhaust Sound
07 2.4 lt, 3" zzp stainless piping, 3" zzp downpipe. new o2s, new headers.
Drove fine for about 1/2 weeks.. Now all of a sudden, sounds like a tractor under the hood.. Especially in gear, past 1st gear.. I tried to duplicate the sound in driveway, in park and in neutral. We can reproduce the sound.. Only when driving it.
Process of checking all the bolts on teh exhaust system right now.. But was wondering if anyone else has experience this and can point in a general direction.
Addition: I did use all the gaskets that came with each kit. Including the manifold gasket, was a single gasket, vs stock 2 gasket set i pulled off.
I'm under it now. Few manifold bolts were loose, and down pipe bolts. All retorqued and made tight again. Drove it around block and noise is still freaking there.
Ill have to grab a towel, but 3" tip on it won't take just a shop rag, lol.
Just tried the towel trick, still didn't replicate the sound, even blew the towel out about 5 feet from tail pipe lol.
All bolts are tight, everything shifted back into place. Still only making the sound when the car is physically driving, if in drive and sitting, no noise, get above 5 mph, you'll hear it and faster you go, louder it gets.
I've dealt with hubs before, deffinently don't sound like a hub. Sound is coming from what sounds like back of motor towards the bottom (checked oil as well, its good).
Just installed brand new hubs, I do understand you can get bad new ones right from box, but that normally sounds like a growl or jet engine.engine this sounds like a tractor motor.
I even checked the 3 bolts at downpipe to resonator.
