What fuse and condition?
I looked for it here but do you all remember the discussion here a while back regarding some darn thing that may happen to the car and the special fuse to fix it was under the hood. Driving me nuts as I want to make note of it all in that huge downloaded manual I have but can't remember what or where but it was important
No, I wish I could remember it. Nagging me like a bad song. it was some thing completely out of left field that seemed like the complete opposite in a repair which was like "oh really, there is a fuse for this and its under the hood?"
Think I'll just go to the fuse schematic later when I get home. If i see it,I'll recall it and let you know. I just remember that when it was written in here somewhere, it was said by a few they had no idea that was the fix for the problem.
From the owners manual;
To prevent the battery from draining while the
vehicle is being towed, remove the following fuse
from the floor console fuse block: 8 (Ignition
Switch, PASS-Key® III+). See Floor Console Fuse
Block on page 381 for more information.
Remember to reinstall the fuse once you have
reached your destination.
Engine Compartment Fuse Block
The underhood fuse block is located on the driver’s
side of the engine compartment. Lift the cover
to access the fuse/relay block.
Fuses Usage
1 Electric Power Steering
2 Rear Defogger
3 Empty
Fuses Usage
2 Rear Defogger
3 Empty
yep... chevy dealer... jumped me wrong in polson mt... they used the two terminals on the underhood fuse box... should of gronded on the bolt on the radiator support....
fuse is a sixty amp fuse... normally NOT available in you local parts store... go to your chevy dealer get a spare or two... about six bucks apeice
used the 40amp rear window defogger fuse in an emergance... suggested by the tech a the polson mt chevy dealer... we had to drive from polson mt to sandpoint id to find a sixty amp fuse... again... this might make a good sticky... how to safely jump your hhr or things you MUST know
no internal hatch release...
battery in the rear wheel welll... can t get there from here...
so on
