What liquid could this be?
Noticed a small spot of bright yellow snow under the car when I moved it this morning (no, there was not a dog lifting his leg under my car). Looks like it is under the left front part of the engine compartment. No idiot lights are on when the car is running. Any ideas what this might be?
What colort is your washer fluid and antifreeze?
They are the only fluids that could be bright yellow.
The factory Antifreeze is more orange but if it was changed to prestone could now be yellow.
The only fluids you have are Antifreeze, Oil, Brake fluid, Clutch fluid [if manual], tranny fluid and washer fluid. Onlytwo could be yellow.
