Where do I find Tire Pressure Sensors?
Old 01-27-2010, 08:28 AM
pjb
pjb's Avatar
I've found snow tires and wheels for my HHR. I'd like to add the Tire Pressure Sensor Monitors but I'm hesitant to pay dealer prices. Can I have the tires mounted and balanced on the wheels and add the sensors later? Can I get cheaper sensors? And can any good tire place configure the sensors or does it have to be done by a dealer? Thanks in advance. Pam
pjb is offline
Old 01-27-2010, 08:50 AM
twistrman's Avatar
if it was me and just for snow tires, i would say skip the TPMS. The system will yell at you all the time, but it would cut the costs. Then when you put the others back on, you're good to go.
twistrman is offline
Old 01-27-2010, 09:00 AM
41pontiac's Avatar
Twistrman has a point, but to answer your question try E-Bay
41pontiac is offline
Old 01-27-2010, 03:31 PM
txbass06's Avatar
IIRC, you can only have one set of TPMS programmed to your car at a time. You'd have to take your car to the dealership and pay them to re-program them every time you switched wheels. Seems like a lot of trouble to me...
txbass06 is offline
Old 01-27-2010, 03:47 PM
esmarkey's Avatar
I had my winter set mounted at Belle tire. They sold me the set of 4 TPMS for $30 and did the programing (which you should be able to do yourself).
If you pay them to mount and balance and purchase the sensors from them, I would bet that they would do the progaming when you swithed back and forth as well.
esmarkey is offline
Old 01-27-2010, 06:02 PM
NO,NO,NO I am assuming we hava a 2008 or newer here you can do the reset procedure for the new sending units, no need for dealership, if you can reset the positions yourself when rotating the tires, then you can replace the sending units (stems) yourself.
donbrew is offline
Old 01-27-2010, 06:44 PM
pjb
pjb's Avatar
I have a 2009 SS and I really like being able to look at the idiot reading telling me what my tire pressure is, but since I'm not really sure what the sensor actually is, it's doubtful that I'd be able to "reset the positions and replace the sending units myself". If I have TPMS in both the winter and non-winter tires, they have to be reprogrammed every time the tires are switched? In that case maybe it's easier to not have the TPMS in the winter tires?
pjb is offline
Old 01-27-2010, 07:17 PM
HHRSSouth's Avatar
Well I'm getting ready to have my tires mounted on some after market rims and I'm not going through the hassle of getting my old tps out of the factory wheels or getting new ones. I can deal with a light and check tire pressure the old fashion way.
I'm pretty sure if you use new sensors they have to be programed by the dealer. If you are reusing your old ones you just do the TPMS recalibration via the book.
HHRSSouth is offline
Old 01-27-2010, 08:21 PM
stephenm's Avatar
http://lowest-bids.com/?q=hhr+tpms&button=GO!
stephenm is offline
Old 01-27-2010, 11:01 PM
HHRSSouth's Avatar
Are you a 100% sure on this for 2008 and newer or is it like I posted previously?
Quick Reply: Where do I find Tire Pressure Sensors?
