Where do I find Tire Pressure Sensors?
to do it yourself involves with a procedure of tapping your brakes etc to put it into learning mode, it blinks a blinker which tire it wants and you let the air out for like 8 seconds, and it honks at you, repeat. It is easy.
But them walking around the car with a computer for 10 seconds is easier.
Come on Twist, your loosing it
There may be another way to reset the oil pressure monitor, but I use the reset button method... It acknowledges that it has been reset, I like that.
yeah you can do one with your brakes too, for some reason mine didn't want to do it with the reset button the one time, so I did it the other way.
#26
If a gas station with an air hose is close by, this method should work as well.
