Where is the Horn located HHR SS??
HHR Horn
There are a few screws under the left front fender liner and some plastic pins to remove. I replaced my single OEM unit with a dual tone horn. The fuse for the horn is #60 and the relay for the horn is #55 both are located within the fuse block under the hood. I was inspired to make the change from other posts here at chevyhhr.net, I had to remove the OEM horn to make room for the dual unit. I performed a load test to assure I was not exceeding a 10 amp draw from the new horns. The wire gauge (size) to the horn from the fuse block does not appear to be able to handle much more than 10 amps.
Good Luck with your project.
impulse91
07-16-2009 09:57 PM
