Where is the PCV valve?
Old 04-27-2018, 09:21 AM
Tractorsmith's Avatar
Burning oil ill
Sorry, one thread. Not much for reading all the technicals.
Yes, hard.
Yes, stop and go.
Timely oil changes? Not so much.
Quality oil? I could cry. I did my best ol girl.
Additives you say?
I've seen the shelf of snake oil at O'Smilely's. Didn't have much luck with their oil :'/
Is there a specific product you fellas can recomend?
Tractorsmith is offline
Old 04-27-2018, 09:23 AM
Burning oil ill
A quart per 1,000....... Not sure. I will closely monitor this situation.
Old 04-27-2018, 09:33 AM
The on snake oil that has a chance is pouring an oz or 2 of SeaFoam in each cylinder and let sit over night maybe a few times. That might clean out the oil control rings, if that is the cause.
donbrew is offline
Old 04-27-2018, 09:36 AM
Sounds like your first impression may have been right, you may have cylinder wall/ring wear. You could perform a compression test if you want a better idea of how bad the damage is. Most auto parts stores have a 'loaner' program.
I can't say anything about products, I've never needed them. You could look into Restore, see if you think it would help. It depends how badly worn the engine is.
RJ_RS_SS_350 is offline
Old 04-27-2018, 09:40 AM
I was thinking compression rings, allowing the crankcase to pressurize, and forcing oil vapor out through the PCV orifice.
Old 04-28-2018, 08:51 AM
Thank you
Madmatt6988
04-07-2014 09:38 AM
socalHHRguy
02-08-2012 04:08 PM
TucsonHHRSS
34
10-13-2010 01:50 PM
Money in the Bank
09-23-2007 04:48 PM
Quick Reply: Where is the PCV valve?
