whining noise when i steer HELP
finally we fixed it today and as i was leaving it stated a little bit again. it doesn't do it constant just every now and then. GRRR 3 dealers and no one knows.. i am making a trip south and hope like hell nothing breaks. they pulled steering column out and apparently repacked it with grease they told me. i don't see how that possible but what ever.
Condition #7
Some customers may comment on a whine/hum noise from the steering column while making right hand turns at 5-15 mph (8-24 km/h). A slight whine/hum noise is considered to be normal for EPS so it will be helpful to compare to another like vehicle. If the vehicle exhibits excessive feedback/noise when compared to another vehicle, follow the correction procedure below.
Correction #7
Important: DO NOT replace the steering column.
Pull the 60 amp steering fuse (1) in the underhood fuse block. If this eliminates the whine/hum concern, contact the Technical Assistance Center for further information in order to repair the vehicle. If this does not eliminate the noise, continue to diagnose the vehicle according to the diagnostics in SI.
Correction #7
jdelanjo
08-26-2020 08:13 PM
