Who's HHR has the most Miles
Old 05-20-2010 | 04:53 PM
LinkX's Avatar
I am wondering, I put on 30K+ a year, I use it as my service car, I've going to turn 111000 miles tomorrow, so how many miles can I expect before major overhaul?
Old 05-20-2010 | 08:59 PM
blue car's Avatar
mine will have had it a month and 10 k is already on the clock. it 's a work car but a fun one
Old 05-20-2010 | 09:27 PM
SmootHHR's Avatar
got me beat...my 06 will roll 96k next week
Old 05-21-2010 | 02:42 AM
geesh's Avatar
Almost 60,000 miles since august 09
Old 05-21-2010 | 02:35 PM
thedonn007's Avatar
I am at 120,000 miles, I had the HHR since 02/2006. Only issues are the broken shift interlock, rust at the hem of the door outer to door inner panel at the bottom of all 4 doors and rust on both rear door panels just below the plastic splash protector that is glued to the side door just in front of the rear wheels.
I had the problem with the water leaking though the air filter, which caused an inch of water on floor on the passenger side. I actually had to have it repaired twice. The same issue also led to my blower motor resistor having to be replaced twice do to water damage.
Sometimes my rear wiper does not work. Sometimes the washer fluid does not dispense from the rear either. Sometimes one works and the other does not. It is rather strange, but it has been working for the past couple of months.
Old 05-21-2010 | 02:39 PM
goetylsd's Avatar
Mine has 103,000 miles now. The biggest thing I had to fix was the O2/oxygen sensor.
Old 05-21-2010 | 02:45 PM
SindyDix's Avatar
I think Zman has racked in the miles..... Oh Rudy.... where are you?
Old 05-22-2010 | 07:29 AM
TomsHHR's Avatar
One member that was a courier had 120,000 on his 2006 HHR back in 2006, Think where he would be 4 years later.
Old 05-22-2010 | 11:20 AM
LinkX's Avatar
So far this month I have put on 1600 miles, just this week I started using mid grade gas and I noticed my mpg is up when driving 70mph, usually I get 28-29 @ 70 but yesterday on a 500 mile trip got 32.7, and did it in one tank.
Old 05-22-2010 | 11:39 AM
Lil Cheney's Avatar
Did any of you install new timing belts during this ?
