Who's running a GPS in their HHR?
Originally Posted by 1BadPig
The biggest advantage of GPA versus paper is that I can do a reroute quickly in case there is traffic jam/accident ahead. The GPS proved useful this summer while on vacation to detour me around 2 fatal accidents on the interstate highways.
Originally Posted by teech
ditto...no go on the dash mounting though...
Hey I'm trying to put mine in the back seat...since it's all verbal
Originally Posted by DaJoker
Most will re-route for you automatically as soon as you go "off course" from the original route.
#27
Originally Posted by stevflo
OK, part of the question answered. How do you get the original info in there? I only see a couple of buttons on the front. Do you use zip codes or does it pull up some kind of menu that you scroll through to enter data??
The DeLorme software, on my other method, IS upgradable each year. I pay about $20 after rebates (not necessary unless you what new updates).
As far as using the unit and IT knowing where you are...it takes the GPS reading and loads the map of that current location. You can scroll through other locations to develop "waypoint" to "waypoint directions and map.
#28
hmmm, i thought these GPS devices used an SD card that you insert into them and it has the maps on the card, reads the maps, gets your bearing with the satellite and works that way...
guess I was wrong about that.
#30
