Wife Wants to Keep Our HHR.....Forever
Old 01-01-2018 | 10:25 PM
And that is why one is supposed to check the oil level periodically, yet many people don't.
Old 01-01-2018 | 11:32 PM
tucsondivots's Avatar
Thanks for the input! Coolant was changed when thermostat replaced 2 weeks ago. I do not know if shop used the Delco part. Gauge shows normal temp and no code since repair. They used 50/50 Dexcool mixture. I am taking it in for the stuck key (hopefully warranty repair) tomorrow to the dealership. Then we will get some quotes on the items suggested here.
Old 01-02-2018 | 07:21 AM
Originally Posted by Oldblue
Yes, Dexcool change every 5 years
The correct AC Delco thermostat 131-158 is a must!
Check things as you feel an difference in handling
Tie rods , steering rack, lca bushings , brakes ( I recommend an upgrade to SS non Brembo)
Rotors and caliper brackets , you will reuse the OEM calipers and pads.
And here’s the big tip! Don’t jump to conclusions when something goes wrong, DIC message, MIL or CEL light, log in here and we’ll get ya thru it!
Thanks. I do not come to this forum often, but the quick, knowledgeable responses are much appreciated.
Old 01-02-2018 | 09:08 AM
You’ll find out if they used the correct thermostat!
Old 01-02-2018 | 02:19 PM
spacer's Avatar
I bought mine at about 80,000 miles, and have 185,000 on it now. Though there have been a couple issues, this little car has been fabulously reliable.
I have done much of what's been listed here, and have a belt and hoses on my to-do list.
I didn't originally plan for this to be a "forever" car, and still occasionally threaten to sell, but dang.... I know it'll be ready to go when I am.
Old 01-02-2018 | 08:42 PM
cc732's Avatar
Well Tucsondivots... They gave you a lot of good tips (some I didn't know about either!)
All I can say is use a good brand of gas, (not the cheaper off-brand discount stuff) to avoid spark plug fouling.
Clare
