Will 245/30zr20 90w tires fit on a ss
The height of that tire is 25.79", so in theory it will work. 26.3" being the max on a SS with stock rims.
Problem is, there's no way to tell since you didn't list the offset on the 20's.
Fwiw. 20's in that size will have very little sidewall. It's gonna ride rough as all get out.
I recommend keeping with the 18's. I have 245/40 18's and they don't have a ton of sidewall(If that's what you're going for), but enough to save me from potholes and such. SS Fan, at one point in time, had (correct me if I'm wrong here) 255/40 18 with little to no rubbing. As Fireman said, the max for the SS is about 26.3", 245/45/ 20 would put you at 28.7".
