window tinting
Old 09-20-2009, 10:35 PM
stephenm's Avatar
I bought a DIY kit, and haven't got around to doing it yet.
the only problem I see, is you cut the film on the outside of the window, and the mirror assembly hangs over the edge of the window area, so you'd really have to be careful.
I've applied clear bra's so I am comfortable working with film.
stephenm is offline
Old 09-20-2009, 10:47 PM
Another important point of tinting, is keeping the outside & inside glass SUPER Clean.. Dirt particles are the enemy..
You can get a perfect cut to fit, but when squeegeing (spelling ?) it out only to find a single spec of dirt can really change the mood of the day..
sleeper is offline
Old 09-21-2009, 08:12 AM
MikeloftyHHR's Avatar
here in Florida there are tint shops everywhere... got all mine tinted to %5 over the factory for about 100 bucks....supply and demand I guess huh?
MikeloftyHHR is offline
Old 09-21-2009, 08:21 AM
SOMBERSHARK0714's Avatar
Tinting is best left up to the pros. That is all.
SOMBERSHARK0714 is offline
Old 09-22-2009, 08:03 PM
*jerdog*'s Avatar
Blat!!!! I wanted to do mine also, but 240 to do all the backs to 5%, and do the fronts to 20% seems like a far better deal then me using every swear word I know for the better part of a saturday. :-))
*jerdog* is offline
Old 09-22-2009, 09:59 PM
HHorange's Avatar
Tinted my own. This is the first time I have used a precut film. It worked out fine. I would however recommend that if you have never done it before, buy two sets. You will most likely mess up the first set in the learning process.
Heck even a couple of sets to mess up and your still cheaper than a pro job. The precuts are cheap on Ebay.
I also foound that it was a lot easier to get the tint right if I pulled the inner door panels off first. The pre cut film went a good ways down past the inner wipes.
HHorange is offline
Old 09-22-2009, 10:20 PM
THE BATMAN's Avatar
Bought the tint, after geting started and detroying the 1st pc, I decided this would be the 1st mod done buy someone other than me. Still hav'nt got it done.
THE BATMAN is offline
Old 09-22-2009, 11:49 PM
HHorange-
When you squirt the windows down with the soapy/water mix, it's very easy to slide the excess tint down past the inner wipes..It will adhere to the glass, but give em 2-3 days before you power down a window..
Any stubborn areas use a blow-dryer & work em out carefully..Always wetting the outside side of tint to prevent any scrape marks or etc while squeeging it.
sleeper is offline
Old 09-23-2009, 01:49 PM
HHorange's Avatar
I have tinted a number of cars and trucks.....and while it is true you can tint the windows with the inner door panels in place I just find it easier to pull the inner panels. especially since it takes all of about 15 minutes to pull both front door panels on an HHR.... Its just personnel preference.
It just might be easier for a beginner with the panels and dew wipers off......
HHorange is offline
Old 09-23-2009, 03:39 PM
Cityboynow's Avatar
WOW wolfman I got a deal since the glass company here only charged me 50.00 for both
front windows on my 09 I just bought. OK so I am happy. Have a good day
Cityboynow is offline
Quick Reply: window tinting
