Wiring diagram for oem fog light switch
I'm looking for the wiring diagram for the oem fog light switch , I'm going to wire my fog lights using an aftermarket setup as I have a 2009 LS and it dosn't have the required wirng to do it as it would be from the factory, the only harness I have is to the switch there is nothing from either fuse box so I would like to use the stock switch in place of the one I got in the aftermarket kit, so I just need info on wiring from the OEM switch thanks John B.
