Wiring under front seats?
Old 07-27-2020 | 08:52 PM
Nasaathoff's Avatar
A friend and I were talking about potential mods to my 2008 HHR this weekend, and adding heated leather seats were brought up. After looking under the driver’s seat, my friend saw a few wires under there and saw one that one was cut. What are these wires? The seats are completely manual
I’m posting photos of the wires under both front seats, the one with the cut wire is the driver’s side.
Old 07-31-2020 | 09:32 PM
If you don't buckle up, does a chime sound ? If not, that may be the cut wire.
Cause both seats have sensors to tell if there are 1 or 2 people in front seats.
Old 08-01-2020 | 09:19 AM
Could’ve been the power seat or lumbar support control wires.
Old 08-01-2020 | 11:31 AM
Cat Man HHR's Avatar
Are you asking this question because you do have heated seats to install ?
Or are you showing the driver and passenger seats in the car ?
Old 08-01-2020 | 03:43 PM
The large connector on the Passenger side is the passenger presence system.
Does the fasten seat belt warning work? That might be the wires for it. The switch is in the buckle, any wires flopping around?
Old 08-01-2020 | 04:25 PM
Nasaathoff's Avatar
It seems to be the seatbelt light, as the chime didn’t sound and the light didn’t come on this morning when I got in.
Leather heated seats is just an upgrade I’d like to do in the future.
Old 08-01-2020 | 10:16 PM
Well, good that is sorted out then..
But if the wire has long been cut, then the passenger presence system would not have been working for as long as that wire was cut. Eh ?
Old 08-01-2020 | 11:06 PM
The cut wire is under the driver seat. Mine chimes when the door is open, key in. Doesn't matter if I'm sitting in it or not. I guess I don't know what the wire actually is for.
EDIT: seat belt chime, got it.
Old 08-01-2020 | 11:55 PM
It seems to be the seat belt warning. The one that lights up on the dash and chimes if you don't buckle up in gear.
The key in chime works when the door is open with key in, nothing to do with the seat. Only the passenger seat needs a presence sensor (to turn the airbag on/off).
Old 08-02-2020 | 10:45 PM
I would concur with that assumption..
