Zero throttle fuel usage?
Well, so far nobody has given the correct answer.
Most of the newer engines today have what is called DFCO (Deceleration Fuel CutOff). When certain operating parameters are met, fuel is cut to the injectors. It helps with both mileage and emissions.
When the engine approaches idle, fuel resumes to prevent stalling.
I see it all the time with my wideband O2 sensor and during tuning data logs.
Whether manual or automatic, putting it into neutral will circumvent DCFO. So, for mileage, you are better off just leaving it in gear.
Hope that helps.
EDIT... Well pitbull answered right while I was typing.
Hope that helps.
A Crazy Canuck
Fuel Economy - Hypermiling
23
01-11-2013 06:29 PM
Redshift
12-10-2010 09:48 PM
