2008 SS Idle Issue
ahhhh the P0171!!! (always post the code, not the description) - Did you try the SEARCH tool at the top of the page? Punch in P0171 and it will give you a mess of links detailing the various causes: leak in the flex pipe that attaches to the exhaust manifold, bad fuel pump, evap purge solenoid etc..
You mentioned problems after topping up the gas tank - I'd suspect the evap purge solenoid. The flex pipe at the exhaust manifold is pretty easy to check just don't burn your hands on it when checking it (not a whole lot of room there when reaching down from the top of the engine).
Franco Fanfuria
04-13-2011 11:30 PM
