6 speed
Old 02-13-2012 | 02:04 PM
  #31
Yonash's Avatar
if i recall correctly, back when the SS was released, there was talk about the car actually being tested with the 6-spd from the 9-3 (remember, our engine and trans came from Saab), and found that without going through and completely re-engineering and calculating every ratio, the 5-spd ended up being faster and more economical. so they saved money and put the pre-existing 5-spd in, instead of spending the time and money on figuring out which ratios would be required for the 6. i can't remember where i read this at, as it was quite some time ago, and my memory could also be a bit foggy on the specifics, but i believe it was something like that.
Old 02-13-2012 | 05:02 PM
  #32
jsis7895's Avatar
2006 F40 (MT2)
Type: transverse front wheel drive, six
speed manual transaxle
Engine range: 3.9L
Maximum engine torque: 245 lb-ft ( 333 Nm )
Maximum gearbox torque: 295 lb-ft ( 400 Nm )
Gear ratios: MT2
First: 3.77 13.3835 final 6000 RPM 34.68 MPH
Second: 2.04 7.242 final 6000 RPM 64.08 MPH
Third: 1.32 4.686 final 6000 RPM 99.04 MPH
Fourth: 0.95 3.3725 final 6000 RPM 137.61 MPH
Fifth: 0.76 2.698 final 6000 RPM 172.02 MPH 3000 RPM 86.01mph
Sixth: 0.62 2.201 final 6000 RPM 210.86 MPH 2500 RPM 87.86 MPH 2000 RPM 70.29 MPH
Reverse: 3.54
Final Drive 3.55
2006 F35 (MU3) <<< FastFiero's choice of transmissions for the 3800SC and LS1 future installs.
Type: transverse front wheel drive, five
speed manual transaxle ( optional
with limited slip differential )
Engine range: 2.0L I-4 supercharged
Maximum engine torque: 200 lb-ft ( 271 Nm )
Maximum gearbox torque: 258 lb-ft ( 350 Nm )
Gear ratios: MU3
First: 3.38 13.6552 final 6000 RPM 33.90 MPH
Second: 1.76 7.128 final 6000 RPM 65.11 MPH
Third: 1.18 4.779 final 6000 RPM 97.11 MPH
Fourth: 0.89 3.6045 final 6000 RPM 128.76 MPH
Fifth: 0.7 2.832 final 6000 RPM 163.70 MPH 3000 RPM 81.85 MPH
Reverse: 3.17
Final Drive 4.05
bolth transmission out in 2006 1-3 gear almost identical 4th very close and then economy for the 6 speed, crap for the 5. 5th gear in the 6 speed is more economical then the 5th in the 5 speed so even if you forgot you had a 6 th gear you would still be getting better mpg's
Old 02-13-2012 | 06:00 PM
  #33
theres nothing you can do that can't be done, all you need is CASH, and more CASH, it would not be worth the headaches!!!
XtremeSS
Drivetrain (Excluding Engine)
15
01-28-2015 01:25 PM
slimsol
05-01-2010 10:41 AM
1lowlesabre
06-04-2008 05:03 PM
Clevelandhhrss
05-04-2008 03:18 PM
