Boost gauge when key is on?
Old 05-31-2008 | 07:18 PM
InkTheFlesh's Avatar
Just seeing what everyone else's boost gauge does when you first turn the key on. Mine just sweeps up to 5 psi and drops back down. Is it supposed to do a full sweep, or is mine not acting right? I just noticed my boost gauge light flickers at idle, and I thought maybe these 2 things had something in common. Thanks for the help.
Old 05-31-2008 | 07:55 PM
c2vette's Avatar
The partial sweep up and back to zero is normal start-up routine. Don't know what is up with your light flickering, other than you are not the only one to report that issue.
Old 05-31-2008 | 09:32 PM
dpoll995's Avatar
i never paid attention to the sweep on start up, but i have noticed sometimes the back light kinda flickers soemtimes. i havent taken it in yet, still got plenty of time for that, i just added to my list of things for the next trip to a dealer.
Old 06-01-2008 | 06:31 AM
Chevy SS's Avatar
Mine flickers too at times, it's going to the dealer Tuesday for that among other things.
Old 07-25-2012 | 04:46 PM
Tyler Harvey's Avatar
Mine sweeps up to zero, then slowly builds pressure. Does anybody have a boost gauge acting weird? Mine has swept to zero, gone down and then back up before on start up.
Old 07-25-2012 | 06:56 PM
ChevyGuySS's Avatar
mine flickers too, im thinking its a bad ground to the BCM
Old 07-26-2012 | 02:02 PM
lazaino's Avatar
If the sweep is on purpose, they usually only sweep far enough to ensure that they don't get trapped over on the right. 4th gen F-bodies sweep the tach and speedo full range only if the battery has been disconnected. I guess they're assuming it's not likely that the car was turned over while the key was off. Late model Vettes always sweep full range, I guess to impress the drivers.
Ira
Old 07-27-2012 | 06:49 AM
BZERKED's Avatar
the needle jump is normal as the stepper motor in the gage is running a diagnostic to make sure it's operational. I took mine in in 08 for the flicker and they fixed it (by replacing the gage) under warranty and there was a buletin about it, but it started doing i a year later, it's a bad wire I think.
Old 11-15-2012 | 07:05 AM
backinblackss's Avatar
On my boost gauge, it usually sits on the 20 or 30 underneath the zero instead of on the zero while driving, unless I kick it. Is the gauge supposed to be sitting on zero during normal driving ?
Old 11-15-2012 | 11:33 AM
IgottaWoody's Avatar
No..unpressurized and under low load conditions, the the eng operates in a vacuum ( below zero), as power demands go up it will rise depending on the load and demand. A non turbo'd car will see zero at wide open throttle,and 20-30 at idle and steady no load cruise, zero is equal to atmospheric pressure.
Quick Reply: Boost gauge when key is on?
