The Boost Spike corrected...
Where is the tube that needs to be tightened going to the turbo?
I tightened both hoses coming out of the intercooler and the hose directly behind the airbox, are there more connections I need to check?
I just had the same problem. Low boost in 1st and would bog when launched on the launch controll. I just had the GM stage kit done and thought it was something they did. I didn't notice this before cause over the winter with the snow tires on it I would take it easy in the first 2 gears.I read on here about you guys and the boost hoses so I checked them. They were all loose. But the worse was the air intake from the air box to the turbo is was so loose I could move it by hand. I think it's time to get the Hahn intercooler and hoses:)
Thanks guys for the help finding the problem with the hoses.
