Changing SS fog light bulbs?
To change the fog bulbs, do you need to remove the wheel well covering, or can you get at them from underneath? I don't have jackstands or anything to put the car up on to look underneath, so I figured it'd be easier to ask here. Thanks in advance...
Ugh...tried and failed miserably to get the buttons out to pull the fender liner back. I'm not exactly "handy". I'm afraid of putting too much force on them, and was using a flathead screwdriver since I don't have a panel popper right now. Looks like a trip to Home Depot.
Get a panel popper... it's simply not doable (if you want to retain your sanity) without one. However, I'd be surprised if HD has these. You may want to try a well stocked auto parts place (NAPA or other "real" store... probably not Pep Boys type stores).
Can't explain why Pep Boys wouldn't have a clue. I've never set foot in one of those stores.
