could I have the last one made??
Old 05-15-2016 | 11:14 AM
indy87's Avatar
The last SS
When I was looking to buy an 2010 HHR SS one of the cars I was looking at was a red SS. I ran the vin thru Compnine And it said it was made on 6-15-2010. Here is the print out. Originally Posted by acpantera View Post
Looking around some, I noticed that the last ss production was supposed to be june 4th 2010. Car fax shows mine available for sale on june 5th. The sticker on the door says 6/10. Does anyone know the build dates? My vin is 3GNBAHDMXAS645211.
According to GM, the build date was 6/3/10. It was invoiced to the ordering dealer on 6/5.
What do you think? Report for..
3GNBAHDM5AS645665
Vehicle:
Not Listed
Year:
2010
Build Date:
2010-06-15
RPO Description
UAF DISPLAY MULTIPLE INFO DISPLAY-MID MULTIPLE INFO DISPLAY(UAF)
UD0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT RH/CHILD PRESENCE DETECTOR FRT RH/CHILD PRESENCE DETECTOR(UD0)
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
UJM TIRE PRESS INDICATOR MANUAL LEARN MANUAL LEARN TIRE PRESS IND(UJM)
UPF WIRELESS INTERFACE SHORT RANGE, VOICE REC VOICE REC WIRELESS INTERFACE(UPF)
UQ3 SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3)
UUI RADIO AM/FM STEREO, SEEK/SCAN, CD, AUTO TONE, CLOCK ETR, MP3, RDS, USB PORT AM/FM STEREO W/CD, RDS, MP3 & USB PORT(UUI)
U2K DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VT7 OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
VY7 KNOB,TRANSMISSION CONTROL LEVER,LEATHER LEATHER SHFT KNOB(VY7)
V8D VEHICLE STATEMENT US US VEHICLE STATEMENT(V8D)
YF5 CALIFORNIA EMISSION CERTIFICATION CALIFORNIA EMIS CERTIFICATION(YF5)
ZAF TIRE SPARE SPARE, COMPACT SIZE, 15" COMPACT SPA TIRE(ZAF)
ZAG WHEEL SPARE, COMPACT SIZE, 15X4, 5 LUGS" SPA WHL(ZAG)
1SS OPTION PACKAGE #16 OPTION PACKAGE #16 (1SS)
1SZ PACKAGE OPTION- (1SZ)
19C TRIM COMBINATION,CLOTH,BLACK (19C)
19I INTERIOR TRIM COLOR (19I)
ADM RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, DUAL STAGE DUAL STAGE DRIVER & PASS SEAT INFLATABLE RESTRAINT SYSTEM(ADM)
AJ6 ADJUSTER SEAT, POWER, 6 WAY, VERT, DRIVER 6-WAY PWR D/SEAT ADJ(AJ6)
ASF RESTRAINT ROOF SIDE, LH & RH, INFLATABLE LH & RH ROOF INFLATABLE RESTRAINT(ASF)
AS5 SEAT,FRONT BUCKET(DELUXE) DELUXE FRT BKT ST(AS5)
AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING RR SEAT RR FACING CHILD RESTRAINT PROVISIONS(AT8)
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B36 MAT,LUGGAGE COMPARTMENT LUGG COMPT MAT(B36)
CF5 ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5)
C2Y GVW RATING 4,240 LBS. 4,240 LB GVWR(C2Y)
C67 AIR CONDITIONER,FRONT,ELECTRONIC CONTROLS A/C FRT ELEC CONT(C67)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER ASH TRAY & C/LTR(DT4)
D48 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR ELEC R/CON PAINTED O/S MIR(D48)
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81)
EF7 COUNTRY UNITED STATES OF AMERICA (USA) U S A(EF7)
FE5 SUSPENSION SYSTEM RIDE, HANDLING, PERFORMANCE PERF & HANDLING SUSP(FE5)
FQ7 RATIO TRANSAXLE FINAL DRIVE 4.05 4.05R(FQ7)
GCN PRIMARY COLOR EXTERIOR, VICTORY RED EXTERIOR COLOR(GCN)
G85 AXLE LIMITED SLIP, FWD LIMITED SLIP FWD AXLE(G85)
IPC TRIM,INTERIOR DESIGN (IPC)
JJD I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJD)
JL4 CONTROL ACTIVE BRAKE ACTIVE BRAKE CONTROL(JL4)
J56 BRAKE SYSTEM PWR, FRT & RR DISC, ANTILOCK, FRT & RR WHL, HEAVY DUTY HVY DUTY ANTILOCK BRAKES(J56)
LNF ENGINE GAS, 4 CYL, 2.0L, DI, ALUM, DOHC, TURBO, GM 2.0X(LNF)
MM5 TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION) 5-SPD M/TRANS PROVISIONS(MM5)
MU3 TRANSMISSION MAN 5 SPD, SAAB, 76.5 MM, 3.38 1ST, 0.70 5TH 5-SPD MAN/TRANS(MU3)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NU1 EMISSION SYSTEM CALIFORNIA, LEV2 CALIFORNIA LEV2 EMIS(NU1)
NW9 TRACTION CONTROL ELECTRONIC ELEC TRACTION CONT(NW9)
PZ4 WHEEL 18 X 7.5 ALUMINUM, POLISHED ALUM WHL(PZ4)
QOI TIRE ALL P225/45R18-91W AL3 BW TIRE(QOI)
R9N CONTROL - SALES ITEM NO. 89
SAL PLANT CODE- RAMOS ARIZPE, MEXICO GM DE MEXICO RAMOS ARIZPE,MEXICO PLANT CODE(SAL)
SLM SALES PROCESSING - STOCK ORDERS
T96 LAMP,FRONT FOG FRT FOG LP(T96)
Old 05-15-2016 | 11:38 AM
Don't worry about! Keep her clean and drive her often!!
My 1988 C1500, extended cab long bed, looked like a project when I bought it!
The rad was narrow and matched up to an 87 C10!
The drivers inner door panel had no badges!
The passengers inner door panel hands Cheyenne badge?
The two piece drive shaft was stamped March 1987.
I had GM Canada run a spec sheet on it, turns out it was built on April 17th, 1987.
The first week of test production runs, it came with a Chevrolet grille and a GMC grille
The tailgate had a GMC badge
I called up to Oshawa , Ontario, they confirmed I had the first of the extended cab pickups, GM ever built!
But I still redid it to my liking, drove it for twelve years 650,000 kilometres, and sold it for a 5 digit price! Yes that's before the decimal point!!
Old 05-15-2016 | 12:10 PM
This attachment might help you, you will need to research a bit more though. Note that in 2010 GM calls the HHR a light truck.
from Edmunds dot com :
" The letter or number in position 11 indicates the manufacturing plant in which the vehicle was assembled. Each automaker has its own set of plant codes.
The last 6 digits (positions 12 through 17) are the production sequence numbers. This is the number each car receives on the assembly line. In the case of our Cadillac ATS, it was the 125,409th car to roll off the assembly line in Lansing, Michigan. "
So, your car was number 645,665 off of the line at the Mexico plant. It is unclear to me if that is total from the factory or just the HHR line. Several other car lines came from that factory, sad to say Aztek was built there.
File Type: pdf
Old 05-15-2016 | 01:28 PM
indy87's Avatar
The car I posted is not my car. Mine was made 5-15-2010. For historical purposes this post say's the last SS, According to GM, the build date was 6/3/10. The SS I posted was made on 6/15/2010. So clearly the last SS wasn't made on 6/3/2010.
Old 05-15-2016 | 02:07 PM
So, what are you getting at? Were you debating/correcting a point made 5 years ago?
Did you notice that the last post in this thread is dated 3/23/2011? So long ago that I assumed you were asking a new question.
Chillydip
03-24-2013 09:51 AM
breds2k
09-03-2012 07:00 PM
bigjacksauto
08-14-2012 02:47 AM
08SSREDHHR
41
06-14-2012 08:20 PM
Firewatcher
11-10-2007 04:27 PM
Quick Reply: could I have the last one made??
