Dropped a BPV bolt... HELP!
Old 03-20-2012, 05:15 PM
hotrodredss's Avatar
Exclamation Dropped a BPV bolt... HELP!
Dropped one of the bolts to the bpv behind the engine and it didn't hit the ground. Can anyone give me some ideas how to find it?
hotrodredss is offline
Old 03-20-2012, 05:17 PM
Breadfan's Avatar
Maybe one of those telescoping magnet tools?
Breadfan is offline
Old 03-20-2012, 07:14 PM
moonsign's Avatar
Oh! you did that too.
I dropped one of the bolts myself, that did'nt hit the ground. Crawl under and it will be one the lower cradle[frame] somewhere. "Moon"
moonsign is offline
Old 03-20-2012, 07:53 PM
JeramieJJ's Avatar
Get a magnet device on end of aluminum shaft. Allows you to bend to all kind of formats for crevices.
I dropped it also.....took forever to find it.
Mine was not where Moon's was.
-J
JeramieJJ is offline
Old 03-20-2012, 09:05 PM
Breadfan's Avatar
I'm really hoping that reading this will somehow prevent me from dropping the same bolt tomorrow.
Breadfan is offline
Old 03-20-2012, 09:11 PM
What should we do. glue a thread to them, mine will be here tomorrow too.
SS fan is offline
Old 03-20-2012, 09:20 PM
Breadfan's Avatar
Um, that's not a half bad idea, but tie the thread around it next to the head.
Breadfan is offline
Old 03-20-2012, 09:43 PM
i can't seem to find it. At the local hardware store they have the exact same one but a lower grade of it. The dealership said my best option was to just get a replacement and let that one fallout eventually...Will the lower grade make a difference on these?
p.s. I had the dang thing jacked up and the wheel off trying to get in there and see where it went and had no luck...
Old 03-20-2012, 09:48 PM
Breadfan's Avatar
I'm guessing the lower grade would be fine temporarily. Whether you want to leave it that way is up to you.
Breadfan is offline
Old 03-21-2012, 06:25 PM
JeramieJJ's Avatar
Originally Posted by hotrodredss
...At the local hardware store they have the exact same one but a lower grade of it. .....
that will be fine. just needs to hold it on. I doubt the lower grade will be that much of an issue.
Quick Reply: Dropped a BPV bolt... HELP!
