Factory wheel weight
I weighed my HHR SS wheels today, the wheels/tires weighed in at 49 lbs at 37 psi air. If you give + or - 1 lb. for scale error, the TPS and the weight for the stock Michelin tires at 26 lbs/ea, then one can conclude that:
The factory HHR SS wheel weighs between 22-24 lbs/ea. Thats still not bad for factory wheels. and weigh less then some after market wheels.
Thanks for verifying the weight of the rims Steve (and that my scale is off 1 lb ).
Well these are coming out soon $100 cheaper per rim and they are suppose to weigh in at 17-18 lbs.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
OZ Alleggeritas: http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Later
Allex
Lone Ranger
06-05-2007 06:50 PM
