First accident in my new SS =[
Old 11-02-2009, 11:47 PM
JoeyFeduka's Avatar
Just this past Friday, I was driving on the freeway... And to my horror a 2x4 nailed to a 2x4 like a T (both pieces were probably 1 and a half to 2 feet in length) tumbled into my lane. Being that it was so big, and traffic was fairly high, I could not avoid it. The damage was a flat tire, the rim is fairly gouged up, and the ground effects on the drivers side has a 2 foot chunk taken out of it.
So yeah, I won't have my car for probably two weeks.
Always sad to get into your first accident, big or small.
Edit: The spare in my trunk did not fit... It was hitting the brake caliper... Has anyone had this problem?
JoeyFeduka is offline
Old 11-03-2009, 12:35 AM
LBJ
LBJ's Avatar
This is a known issue. The owner's manual advises that you will need to move a rear tire up to the front and put the spare on the rear. I believe this only applies to SS's with the Brembo brakes.
LBJ is offline
Old 11-03-2009, 01:14 AM
JoeyFeduka's Avatar
That makes perfect sense! I thought it was because of the Brembos... The idea of putting the rear on the front and putting the spare on the back has totally slipped my mind... I'm embarrassed.
EDIT:Actually, now that I look back on it. I did check to see if the back calipers were the same... And indeed they were.. or at least I think they were.
Old 11-03-2009, 08:15 AM
jerSSey HHR's Avatar
At least no one was injured. Still sucks to get damage like this.
jerSSey HHR is offline
Old 11-03-2009, 08:55 PM
*jerdog*'s Avatar
sorry for your misfortune.. :'( Hope you get her back in great shape! As was stated, rear to front and spare to rear...keep that gm roadside number handy, in the sumer I'll change the tire....but in a foot of snow, well...I'll let them do it :) Best of luck, Jer.
*jerdog* is offline
Old 11-03-2009, 09:36 PM
JoeyFeduka's Avatar
Ahh alright... I guess swapping the back to the front WOULD have worked... I assumed since the calipers in the back were the same it wouldn't have worked...
DOH X_X
Old 11-04-2009, 09:13 PM
IgottaWoody's Avatar
disc diameter in the rear is smaler
IgottaWoody is offline
Old 11-04-2009, 10:52 PM
JoeyFeduka's Avatar
Guys, looks like I'm in the clear for looking like a moron! My dealer contacted me and infact it was the wrong spare!
PHEW
Old 11-05-2009, 06:23 AM
millerrdjr's Avatar
"This is a known issue. The owner's manual advises that you will need to move a rear tire up to the front and put the spare on the rear. I believe this only applies to SS's with the Brembo brakes."
No, it applies to all SS's not just those with Brembo brakes.
millerrdjr is offline
Old 11-05-2009, 09:30 PM
chudlychudson's Avatar
From the 09 owners manual, applies to all SS:
Removing the Flat Tire and
Installing the Spare Tire (SS Model)
The SS Model has larger performance brakes than
the base model. The compact spare tire will not clear
the front brakes.
Do not use the compact spare tire in the event of a front
flat tire.
You must use the rear tire to replace the front flat tire.
chudlychudson is offline
Quick Reply: First accident in my new SS =[
