HHr SS Electrical Problems Growing
Old 10-24-2021 | 11:37 AM
  #131
MDoherty97's Avatar
Originally Posted by donbrew
They are on different circuits so must be the switch/wires.
The wires for the switches go to the fuse box? Or is there other wires that could be keeping them on? Like as soon as I turn the key they're all on, but turn signal and hazards all work properly
Old 10-24-2021 | 12:39 PM
  #132
Use your eyes and fingers. I can't see from here. Whatever wire you may have touched in the last 14 pages is suspect.
Old 10-24-2021 | 01:55 PM
  #133
MDoherty97's Avatar
It seems since I touched the sensors, I watched a video back to confirm
Old 10-24-2021 | 02:34 PM
  #134
14 pages ago you started messing with wires that you knew nothing about. Since then you have touched lots of wires.
Old 10-25-2021 | 11:35 AM
  #135
MDoherty97's Avatar
I put those wires back as they were, the only things I have touched since are the sensors.
Old 10-25-2021 | 11:52 AM
  #136
MDoherty97's Avatar
what part of the engine fuse box controls what? Like each set of cables with a block, maybe then can dial it down to something more specific
Old 10-25-2021 | 12:11 PM
  #137
Uhh. It's written on the label what each fuse and relay controls. No label ? Look in the Owners Manual. No manual, donbrew has owners manuals listed in his "sig" for download.
Old 10-25-2021 | 12:16 PM
  #138
MDoherty97's Avatar
I mean the bottom half of the fuse box, where theres a bundle of wires that go into a block (5 I think). Because if its the one block bundle under the first half I'm thinking of then I may be able to fix all this
Old 10-25-2021 | 12:35 PM
  #139
Just so we're on the same page:
The lights were on in the back, which you thought were tail lights, part of the DaytimeRunningLights(DRL). Stepping on the brake pedal didn't change the brightness of the lights, so you thought the brake lights didn't work.
Now you've realized that it was actually brake lights that were on all the time.
The DRLs do not illuminate the tail lights.
Old 10-25-2021 | 12:45 PM
  #140
There's no stop light fuse in the underhood fuse block. You'll have to follow the wires from the sensor, through the firewall, and into the fuse block.
It might be interesting to pull the stop light fuse from the interior fuse block, see what happens.
Quick Reply: HHr SS Electrical Problems Growing
