HHr SS Electrical Problems Growing
#55
Even when seated properly I still get nothing :/ but yes I did think that was the problem. What should the voltage be when in accessory and when turning to crank? At acc its 0.22, and at crank its 0.26, is that normal?
#58
I don’t recall and frankly , I apologize for not having time to go back though this thread, did you have the battery load tested? A dead cell or 2 can give you this trouble, have you bench tested the starter motor and solenoid, I just had a similar situation, the solenoid wasn’t engaging the bendix drive. A new starter cured that.
#60
