High output alternator
You might also try the search function on this forum. Several threads discussed this issue and many suggestions were given, including some places to purchase, I believe.
But understand, the alternator in the HHR is unique. Take a look under the hood and see how it's mounted.
And it is in an awkward position....May I ask why you need this for?
There's an AC Delco machine that fits on the same mount, I think 130A, and has a conventional winding, but I'd bet that if it's wound for higher output, there'll be almost no output at idle.
I installed two massive audio qc15's with a p3000.1 to push them, then for the highs i installed diamond audio hex 6" components in the front and back with a massive audio p800.4 to push them added an additional stinger battery and for the deck i put the pioneer avic d3
