Horn installation!
Old 11-18-2011 | 12:23 PM
ChevyGuySS's Avatar
Wink Horn installation!
I'm currently in the progress of installing my 150 psi train horn.
The car has been siting like this or 3 days because I've been too busy but here is what I'm planning
The compressor will go here
The tank will go here
An the horn will go here
Old 11-18-2011 | 01:10 PM
mityqwik's Avatar
Thumbs up
i have been contemplating on getting one of those horns for my HHR instead i installed a small air-horn much loader than the stock horn
Old 11-18-2011 | 02:03 PM
ChevyGuySS's Avatar
Can you guys see it now? I can. But my dad picked it up at the flea market. Mine is just pieced together from different places. But I just got the horn mounted about 30 minutes ago. The little red plastic ones?
Old 11-18-2011 | 02:06 PM
ChevyGuySS's Avatar
Old 11-18-2011 | 04:46 PM
That's not going to set off your airbags when you use it, is it?
Old 11-18-2011 | 04:48 PM
ChevyGuySS's Avatar
I didn't know that loud noises would set off the air bag?? How would it?
Old 11-18-2011 | 04:51 PM
Loud noises can't trigger the bags, I believe Greybeard is joshing you a bit, nice horn install by the way.
Old 11-18-2011 | 05:50 PM
jbman's Avatar
Very nice you could go into business doing them on other HHRs I want to be first in line great job.
Old 11-19-2011 | 09:24 PM
ChevyGuySS's Avatar
Cool
Here is the progress: I have the horn, air tank, and compressor, and switch to go between air horn and factory horn, tomorrow is wiring it all and Monday is plumbing it all
Haha. I have no problem installing one now that I know what to do. The hardest part was coming up with the places to mount everything and the mounts for the pieces. I ended up making a trip to home depot and picking up so 3/4 in square tubing and made a mount for the compressor and the tank mounted right up where the factory horn is, I moved the factory horn just behind the bracket for the headlight and the horn, I just found a piece of aluminum from the screen enclosure around my pool and cut it up and made it work.
Old 11-19-2011 | 10:44 PM
Nice clean install..
note to self: if can't find material to fab a bracket, tear it off my house/fence or whatever is handy..
(J/K)..couldn't resist.
